Posted by Bobcat on February 11, 2010 at 13:51:46 from (69.66.139.140):
In Reply to: F20 engine tools posted by IH nut on February 10, 2010 at 16:06:56:
I pulled the flywheel off a F-30 by installing grade 5 bolts into the 3 holes already drilled in the flywheel. Make the head of the bolts stick out so a really large 3 jaw puller will hook them on the outside. Make a plate to cover the pilot bearing in the crank. As long as everything pulls straight it will pull right off. As far as moving the crankshaft out of the block a block of wood and a good old sledge hammer works just fine. Now to get the bearings off the crank invest in a 50ton press.
Putting things back together requires heat differential on the flywheel and bearings. Nothing real "IH" special needed!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
