Re: M FARMALL
Posted by Andrew Z on February 11, 2010 at 15:02:55 from (64.252.113.90):
In Reply to: M FARMALL posted by ken marlatt on February 11, 2010 at 13:58:45:
Like the others said a 3 jaw puller works well. If that doesnt work or you find yuor sliping off the wheel alot, try a bearing splitter. (clam shell puller) Iv pulled alot this way does not hurt the wheel as bad as putting the jaws right on the wheel center its self.
good luck
Andrew
