Re: Farmall 400 TA questions
Posted by Owen Aaland on February 11, 2010 at 18:23:35 from (65.165.246.14):
In Reply to: Farmall 400 TA questions posted by Nebraska Kirk on February 11, 2010 at 17:20:29:
Looking at the difference in sizes of the two clutches would make one wonder how come the TA can get by with a smaller disk.
The reason is that the TA clutch does not have to hold as much torque as the main clutch because of the gear reduction in the TA. The power is transmitted through the TA gears to the input shaft of the transmission. As the TA reduces the output shaft speed the torque entering the transmission is greater than the torque coming through the main clutch. Since torque is increased as speed is decreased, the opposite is also true. The gearing in the TA has the effect of trying to increase the speed of the TA clutch assembly and thus reducing the torque available. The result is that the TA clutch, even though it is smaller, is able to handle as much HP as the main clutch.
