You can replace the shaft seal in that pump yourself. It does involve some disassemblbly but not to bad if you have the service manual for it. Seals and gaskets can be purchased thru a CaseIH dealer or from a pump repair shop. If that's all that's wrong it should only run a couple hundred at a shop, BUT if the pump needs hard parts it could easily run north of two grand. Most hard parts are no longer made for the German Bosch pumps so you have to find remaining old stock ones or have new ones custom made. Good Luck.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
