IHC 856 tractor
Posted by DMcLean on February 11, 2010 at 20:15:00 from (72.250.148.28):
I have an 856 diesel tractor that I use to pull feed wagon. It has power steering cylinder that leaks off and on. The local mechanic has had this apart and replaced seals and replaced a sleeve the last time and also put in new seals. It leaks a gallon of fluid in about 4 hours of run time. The next time you run the tractor it won't leak at all. Has anyone had a similar experience?
