Re: high octane gas in super m
Posted by mkirsch on February 12, 2010 at 05:23:10 from (64.80.108.56):
In Reply to: high octane gas in super m posted by jdetig1 on February 11, 2010 at 20:35:35:
There are a lot of old wives' tales about 93 octane gas... More power, runs better...
Heck, I've even heard that the higher octane replaces the lead in gasoline... It doesn't.
The compression in the old (pre '06 series) 4-cylinder IH gas engines is not high enough to require high octane gasoline.
Gasoline will ignite with enough heat and compression. This will manifest itself as a "ping" in a gasoline engine... I'm never quite sure about the whole relationship between pre-ignition, spark knock, and ping. They may be the same thing, or maybe not, but I'm pretty sure they all stem from the gasoline igniting before the spark plug fires.
What octane does is basically "stabilize" the gasoline so it doesn't ignite too soon in high-compression engines. The gas goes bang when it's supposed to go bang...
