Re: What can I do to get my H to run better????
Posted by Janicholson on February 12, 2010 at 06:31:11 from (199.17.6.222):
In Reply to: What can I do to get my H to run better???? posted by Kyle Ladowski on February 12, 2010 at 06:18:40:
This site sells good kits to make it into a SH sized engine (thiner sleeves) an Sh manifols and carb will increase the available air (replacing the aircleaner with SH might also be a good idea. Reground puller cam profile will help. as will RPM boost to 2200 high idle.
Correct timing advance surves, a good distributor bushing, and an electronic ignition, will be in the right direction.
If you want more power, running pistons directly in a rebored engine without sleeves, an M carb and stroker crank can be had. All that is missing is money. If you are pulling in local events, go with the rules they set. JimN
