Re: MW 9 speed M vs SM
Posted by D Slater on February 12, 2010 at 08:12:22 from (72.65.129.56):
In Reply to: MW 9 speed M vs SM posted by HSE on February 12, 2010 at 06:50:37:
Yes there different, 4&5 sliding gear and 3&4 gear on the counter shaft. Along with all the parts that press on the counter shaft. Range gears are the same M to SM. On a M with M&W the 4th gear ratio stays the same as IH. On a M&W set up 4th in a SM is slower than the IH 4th.
