Re: high octane gas in super m
Posted by Bob M on February 12, 2010 at 09:19:58 from (151.190.254.108):
In Reply to: high octane gas in super m posted by jdetig1 on February 11, 2010 at 20:35:35:
Save your money!
In engineering school I did dyno testing of various gasoline grades in an early 50’s Jeep flathead 4 and a 60’s Chrysler slant 6. (Both engines have compression ratios similar to a Farmall Super M).
The differences in power and fuel economy between 87 regular and 93 premium were less than the limit of experimental error. (If I recall the premium actually delivered a bit LESS power)
We also tested several aviation gasolines: red (87 octane), blue (100 octane low lead) and green (130 octane ) with similar results.
We learned also tweaking fuel mixtures and timing would make no power improvments when using higher grades.
Bottom line: Go ahead and use premium if you wish – it won’t hurt anything. And the blue Sunoco premium looks pretty in the sediment bulb(!) But unless your Super M knocks at full load on regular, switching to premium benefits only your fuel supplier.
