Re: Farmall 460 hydraulic leak from bottom of TA case
Posted by Alex Tolmachoff on February 12, 2010 at 10:15:39 from (66.182.246.233):
In Reply to: Farmall 460 hydraulic leak from bottom of TA case posted by Alex Tolmachoff on February 11, 2010 at 20:55:38:
I don't have a TA, is the carrier and the sun gear still present to drive the hydraulic and power steering pumps? The hydraulic sysstem seems to be under constant load. (Like the relief valve/pressure regulator are overpressurizing) Could there be a leak from the pump case, or is it more likely to be the seal y'all have mentioned? Any way to determine where it is from through any inspection covers? Thanks for the response. I just bought the tractor last week, and it's turning into a lot of work before I can even use it. I needed it to plow snow yesterday, but no joy.
