Re: Saw-tooth throttle
Posted by D Slater on February 12, 2010 at 10:45:58 from (72.65.129.56):
In Reply to: Re: Saw-tooth throttle posted by CNKS on February 11, 2010 at 18:46:21:
CNKS, no it didn't make it in the parts book, but IH sent out a bulliten to the parts system that the governor control 51348 DAX was being replaced by 361244R11. New sector has square notches compared to present part with saw tooth type notches. Effective at serial # 26561 SH and 71718 SMTA. Both made in May 1954. States that new design complete will interchange with the previous type. Square tooth was also sold under part # 366727R91 and maybe others in IH parts merchandising catologs. Later type was used as replacements after saw tooth type run out and its probably a rare tractor that never had those parts replaced more than once.
