With out a TA you still have seals inside and taking the top cover off you would be able to see where it is leaking from. As for hydraulic staying on high pressure, check your aux valve double to single action setting to be sure pins or not broke or bent allowing valve rotate too far, if that is ok, you most likely have a plugged orfice screen in regulator valve assembly.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
