Re: Where do you buy rings and bearings?
Posted by MisterT on February 12, 2010 at 13:50:21 from (209.152.78.140):
In Reply to: Where do you buy rings and bearings? posted by redFarmallboy on February 12, 2010 at 13:34:44:
Standard rings or over-sized? Have you measured the bore? Have you measured the thickness of the rings?
What size bearings? Standard or undersized? Have you had the crankshaft measured by a competent machinist?
