Re: What can I do to get my H to run better????
Posted by CGtractor on February 12, 2010 at 16:25:39 from (69.50.45.97):
In Reply to: What can I do to get my H to run better???? posted by Kyle Ladowski on February 12, 2010 at 06:18:40:
The 706 piston only works with a stroker crank. Super H oversize (3 9/16) will run on the block with no sleeves getting up to 169 cu in. The big manifold and carb from super h thru 350 will help. Tune your distributor and governor. Later cams from 300 or 350 will improve power also.
