Re: Another leaky M carb problem
Posted by old on February 12, 2010 at 17:45:20 from (4.245.13.215):
In Reply to: Another leaky M carb problem posted by Grandad on February 12, 2010 at 17:08:46:
Give this a try but be sure it is out of gear if you do this and don't just check it once but check it twice at least. Turn the gas on. Count to say 60. Turn the gas off and then try to start it. When it fires up turn the gas back on and go. And yes it could be a float problem but more then likely it is op error and you are choking it to much
