Re: charging options
Posted by Jeff Z. on February 13, 2010 at 04:55:17 from (74.76.3.113):
In Reply to: Re: charging options posted by mike paulson on February 13, 2010 at 04:42:35:
You would need a 12 volt coil with internal resistance or use a ballast resistor on the 6 volt coil. The starter will be ok with 12 volts.
If you have a pos ground system now you will need to switch around the wires on the coil.
It will work either way but better if the wires are switched.
+ side from the battery to the coil.
- side of coil to dist for neg ground.
