Re: charging options
Posted by mike paulson on February 13, 2010 at 04:56:56 from (172.129.154.79):
In Reply to: charging options posted by D Slater on February 13, 2010 at 02:35:57:
Nebraska Cowman said: (quoted from post at 13:51:27 02/13/10) No Mike. Actually 6 volt takes heavier wire than 12 so you are fine there. With no light bulbs the only thing you need to do is put a resistor ahead of your 6v coil. The only electrical gauge on a 300 is the ammeter and it dose not care what voltage there is anyway.
thanks for input Cowman. what type of resistor as far as ohms, would it be like the ones they used on the firewalls of like the old Chryslers.
