Posted by mike paulson on February 13, 2010 at 04:58:27 from (172.129.154.79):
In Reply to: charging options posted by jim in ny on February 13, 2010 at 02:35:57:
Jeff Z. said: (quoted from post at 13:55:17 02/13/10) You would need a 12 volt coil with internal resistance or use a ballast resistor on the 6 volt coil. The starter will be ok with 12 volts.
If you have a pos ground system now you will need to switch around the wires on the coil.
It will work either way but better if the wires are switched.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
