Posted by steveb05 on February 13, 2010 at 05:02:45 from (98.158.64.25):
In Reply to: 1948 Cub posted by FarmallZach on February 13, 2010 at 04:32:35:
Make sure you don't have a vacuum leak at the manifold or the base of the carb.Here is how I suggest you can check it turn the engine over and see if you have gas running out the carb.Then check the #2 or #3 spark plug to see if they are wet. If not you have a vacuum leak . Also if the battery is low on charge that can be a problem if you have a battery ignition. You may be pulling down the amperage with the starter and not have enough voltage to allow the ignition to fire the plugs Steve
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
