Re: 1948 Cub
Posted by gene bender on February 13, 2010 at 05:50:53 from (207.177.56.220):
In Reply to: 1948 Cub posted by FarmallZach on February 13, 2010 at 04:32:35:
Remove plugs and then remove the mag cap by turning engine over with your thumb over #1 cycl you can see if the rotor is lined up with the cap when you are on the compression stroke thats the easiest way to make sure your timing is ok. Iys easy to have the rotor off or even 180 out of time.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
