Re: H Carb leak
Posted by old on February 13, 2010 at 09:47:17 from (4.245.0.64):
In Reply to: H Carb leak posted by flameffects on February 13, 2010 at 09:04:03:
Is that one of those rubber tipped needles?? Does it also have the little spring on it so it will not get stuck?? If you answer yes to either or boh do this and it will probably help. Oh you do also know you should always turn the gas off when you park a tractor right?? Pull that needle back out drop it in the seat and tap on it a few times that will put a set in it and most likely stop your problem
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
