Re: '53 Super A oil leak from front crankshaft seal
Posted by steve alderman on February 13, 2010 at 11:33:50 from (68.81.233.34):
In Reply to: '53 Super A oil leak from front crankshaft seal posted by aquanosis on February 13, 2010 at 10:59:24:
the worst part is getting the pulley off the crank you will need a clamshell puller with any kind of luck you should be done in 4hrs
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
