Re: Adjusting the width on '53 Super A front axle
Posted by mkirsch on February 13, 2010 at 12:19:02 from (67.240.251.254):
In Reply to: Adjusting the width on '53 Super A front axle posted by aquanosis on February 13, 2010 at 11:10:48:
Whether it's never been moved at all or was last moved 20 years ago, you probably can't tell the difference.
Regardless, it ain't gonna go easy. It's going to be pretty much just like the last one.
You can see if it will break loose by removing the clamp and replacing the locating pin with a bolt that's a bit smaller in size. Drive it around on some rough ground and if it's going to bust loose it will. The pin will let it break free without completely collapsing.
Most of these require a big rosebud torch, and some sort of press arrangement. Some people use bottle jacks, some use a port-a-power.
