Re: Farmall engine adapter
Posted by gene bender on February 13, 2010 at 12:35:23 from (207.177.56.220):
In Reply to: Farmall engine adapter posted by Mark Nelson on February 13, 2010 at 09:52:00:
You can make one using 1/4 plate then there is the problem of the pilot shaft to the Olds crank. Then check the starter drive for length and meshing with the engine ringear.
