Re: '53 Super A oil leak from front crankshaft seal
Posted by aquanosis on February 13, 2010 at 12:58:12 from (67.241.20.22):
In Reply to: '53 Super A oil leak from front crankshaft seal posted by pete 23 on February 13, 2010 at 10:59:24:
gene bender said: (quoted from post at 13:25:19 02/13/10) You have to remove the steering sector first. Then use a bearing seperator to remove the pulley and you aint going to get it done in 4 hrs as you have to support the front so you can remove the radiator and steering housing as the pulley doesent come off without removing the steering sector.
Do I need to remove the front cover or governor housing or is the seal removed simply from behind the pulley after it's removed? Farmall Parts.com has what's called a Front Main Seal part #FP24638. Is this the part and are any other washers or gaskets needed? Thanks
