Re: alternate engine for IH 340U
Posted by Janicholson on February 13, 2010 at 15:21:22 from (64.61.211.220):
In Reply to: alternate engine for IH 340U posted by Eric Powers on February 12, 2010 at 19:02:18:
All blocks are similar from 340 to 404, 504, and their industrial versions. They are not all sharing the same internals, and in some cases the front housing will need to be swapped out (as well as other minor things) Earlier engines are not practical to install. Largest stock of the series is 153cid, but it is not a sleeved engine. Many good engines can be found on swathers, combines, and Power units, these might need to have the crank shaft drilled for a pilot bearing, Also be careful of starter location. A front mounted starter will not be the same rotation as a rear mounted one. JimN
