Re: Delco Remy voltage regulator
Posted by jdemaris on February 13, 2010 at 18:21:05 from (72.171.0.149):
In Reply to: Delco Remy voltage regulator posted by RDC on February 13, 2010 at 05:27:39:
Many if not most of the aftermarket regulators ar crap.
I just bought two in row from this website and neither worked right. Both A&I versions of a Delco, but both quite different even though the same part #.
First one had no hardened points in the cut-out area. Tractor would charge, but they'd stick when shut down and I'd have to pull the cover and pry them apart.
I called and they sent a second one. This one was built much more rugged and weighed much more. Night-and-day difference. Put it on and the system chareged at 16.5 volts. So, I had to pull the cover off and adjust the voltage limiter to 14.5. Now it's fine (for now).
So two, new, and both not works as they were shipped.
Also bougt a new Echlin from NAPA for a different machine (still a Delco copy). That was a few years ago. Every spring, I have to pull the cover off and file the points in it (for the voltage limiter). Then it will work fine all summer.
I paid $33 for the Delco copy I bought on this Website (A&I brand). I also noticed that John Deere sells their's for almost $100 !! Same Delco cross-reference number. So maybe for that high price, the one Deere sells really is a Delco - or at least made to the same quality level. For Delco # 1118981 or 11118988. Used on IH and Ferguson tractors as well as many others.
