Re: Swapping distributer for mag
Posted by El Toro on February 14, 2010 at 04:36:59 from (74.103.74.58):
In Reply to: Swapping distributer for mag posted by Mike CA on February 13, 2010 at 19:10:09:
When you decide to install the mag you need to see where the rotor is pointing on your distributor before you remove it, THEN Don't move the engine. Once you have the distributor removed turn the rotor on the mag to the same position as it was on the distributor and install it. Make sure you install the plug wires on the cap in the correct firing order:
2-1
4-3 as the rotor rotates CW. Hal
PS: You need to install a switch for grounding out the mag to stop the engine. Disconnect the wire from your ignition switch as you don't need battery voltage for the mag.
