Re: J4 Magneto
Posted by Mike Farmer on February 15, 2010 at 03:38:55 from (86.0.88.107):
In Reply to: Re: J4 Magneto posted by john *.?-!.* cub owner on February 12, 2010 at 19:45:58:
Its done by moving the position of the index plate. Remove the impulse coupling, this will allow you to see the index plate. The plate is held in place with two screws. The plate and the magneto body should be marked. Remove the screws and turn the plate in the required direction to line up with the amount of advance that your tractor requires. Replace the screws and the coupling. Job Done. MTF
