Re: Farmall Super A or Farmall A ?
Posted by gene bender on February 15, 2010 at 08:23:18 from (207.177.56.220):
In Reply to: Farmall Super A or Farmall A ? posted by rlj Indiana on February 15, 2010 at 07:55:48:
The 6-21-w means the block was cast on June 6,1951 But the FAA 197756 is not rite for the SA which you have. The SA #s started with 250,000 in late 47 and your cast# being w should start with 3xxx,xxx. If the FAA# you took off the seat bracket it means that the bracket was changed but your engine# should be in the 300,000 plus range if the code 6-21-w came from the block. Your engine # is below the #1 plug behind the throttle rod.
