Re: farmall F14 Hydraulic oil seals
Posted by Dave Allgire on February 15, 2010 at 14:46:18 from (24.217.36.77):
In Reply to: farmall F14 Hydraulic oil seals posted by Dave A on February 15, 2010 at 09:40:54:
Two things to watch out for. DON"T use a chisel, screwdriver, or putty knife to pry the pieces apart. The various pieces are machined pretty closely and could get damaged. The other thing is the vanes and springs in the vane chamber. The springs keep the vanes in contact with the vane chamber wall and when you pull the shaft out they could pop out. And there are actually two seals on each side, back to back. Probably due to the pressure of the pump. I don"t know what that pressure is supposed to be. Hope this helps.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
