Re: M with a 6 volt/ want 12 volt- what do I need to do?
Posted by Mt. Man on February 15, 2010 at 16:36:54 from (74.47.118.32):
In Reply to: M with a 6 volt/ want 12 volt- what do I need to do? posted by Nolan Jae on February 14, 2010 at 17:03:18:
I would leave it a 6 volt system. After all it worked this long. What I did on my 1950 H was run the ground cable from the battery directly to the starter mounting bolts. I think that rust gets into the joint where the engine and transmission meet, therefore causing it not to get a good ground. Use a good 6 volt grouding wire. Hope this helps
