Mt. Man said: (quoted from post at 17:36:54 02/15/10) I would leave it a 6 volt system. After all it worked this long. What I did on my 1950 H was run the ground cable from the battery directly to the starter mounting bolts. I think that rust gets into the joint where the engine and transmission meet, therefore causing it not to get a good ground. Use a good 6 volt grouding wire. Hope this helps
Long cables, especially ground cables, on a 6v system are not a good idea. Even if they are clean they invite a lot of resistance build up. mike
