With out knowing what coil you have and whatn resistor your using and how long it takes that resistor to warm up to start dropping the voltage to the coil i am shooting in the dark here . When i do a 6 to 12 change over i use a 6 volt coild usually the stock coil and add a resistor off a older Chrysler product and it takes a bit for the voltage to drop off down to around 6-8 volts . Your feed wire to the resistor should be nothing less then a 14. ga. wire from the push pull ing. switch and you sould have at least a 10 Ga. wire supplying juice from the started pole from the battery to the dash . . JT's has a couple good ideas also .
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
