Re: M with a 6 volt/ want 12 volt- what do I need to do?
Posted by Dave A on February 16, 2010 at 08:34:02 from (71.244.130.41):
In Reply to: M with a 6 volt/ want 12 volt- what do I need to do? posted by Nolan Jae on February 14, 2010 at 17:03:18:
I have a farmall h,ac wd and a ac ca that I put 8 volt batteries in and they work fine. As long as they charge at least 9 volts it will be ok.
