Re: Boosting coil voltage during starting
Posted by gene on February 16, 2010 at 09:17:44 from (66.43.40.73):
In Reply to: Boosting coil voltage during starting posted by mkirsch on February 16, 2010 at 06:30:00:
Check the voltage through the coil while cranking the engine. You are looking for between 6 and 9 volts.
Check battery voltage (voltage drop) while cranking engine.
Check coil polarity - matches current battery ground.
John T's thought - wrong ballast resistor.
Beneficial to find out what and/or where the problem is before making changes.
