Andrew Z said: (quoted from post at 18:07:45 02/15/10) yup, MD though 450D are the same, i think even the
WD9-650D are the same.
Youll be pleased with getting them redone, it made a
world of difference in mine.
Andrew
The F8 is used up through the TD14, with only minor differences. Over the years there were a few changes to the throttle plate design. Even the 18 uses the same bowl and float parts. They are easily cleaned. The main problem area is in the fuel line attachment and just inside where the fuel turns upward to the needle. That little cavity can sure collect some crap.
Also, if cleanliness is maintained, injectors are not hard to take apart and clean. Reassemble with anti-seize on the crush rings. Sending them off means they will get pressure tested and that is usually needed.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
