Posted by pete 23 on February 16, 2010 at 16:22:03 from (173.87.0.197):
In Reply to: starting 560 posted by Yep on February 16, 2010 at 14:05:32:
Trying to start at closed throttle is difficult as you are expecting it to run on the idle circuit in carburetor. I would suggest you look at the carb to govenor linkage when throttle is fully closed , engine not running, and then pull the throttle just enough to crack the butterfly a little. You will notice that very little movement on the throttle lever will fully open the butterfly when engine is not running and cause difficult starting. Most all automobiles were made so when you pulled the choke they openen the butterfly a little and same with the fast idle setup with a automatic choke. Same principle.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
