Posted by bc on February 16, 2010 at 16:42:35 from (65.66.85.240):
In Reply to: starting 560 posted by Yep on February 16, 2010 at 14:05:32:
Guess I'd start with soaking it for a day in a gallon can of berryman's carb soak. Then blow out the passages in the carb body with an air compressor. Sounds like a passageway in the carb body may be plugged.
With it running, spray some starting fluid or carb cleaner all around the intake manifold to see if there is a leak there from a bad gasket or warped manifold. The engine will speed up when it gets a whiff of the ether.
Spray some carb cleaner and then some lubricant around the carb and governor in case the linkage is sticking a little.
I don't think you have an electrical problem but whenever something is hard starting, you want to know the coil, dist. cap, rotor, points, condenser, wires, and plugs are in the best of shape. Check them for the heck of it.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
