Re: International 186 Hydro
Posted by Owen Aaland on February 16, 2010 at 20:38:04 from (198.70.47.146):
In Reply to: International 186 Hydro posted by Brian D on February 16, 2010 at 09:59:38:
After you have changed the oil you need have the tractor running for a couple of minute before you check the oil level. The hydros are checked with the engine running because when in use the hydro housing is completely filled with oil. With the engine stopped the oil will drain back out of the hydro housing to the same level as the transmission.
