Re: starting 560
Posted by fredmich on February 17, 2010 at 05:23:39 from (64.12.116.73):
In Reply to: starting 560 posted by Yep on February 16, 2010 at 14:05:32:
If you let the tractor sit for awhile not running and with the fuel shutoff in the open position does fuel drip from the carb? Your float needle may not be seating all the way (due to wear or a piece of dirt) and causing the float bowl to overfill which can cause hard starting from a flooded condition. When the engine is finally running and warm it may be able to handle the leaky needle valve if it is not leaking too bad. My 560 is the best starting tractor I have...Fred
