Not that there is anything wrong with most suggestions, but to get to the heart of the problem the fastest way possible, go with BOB M and, " Try measuring the coil primary current with the ignition on and the engine stopped (points closed). A properly sized coil and ballast resistor package should draw 3 – 4 amps. Less than that says either your coil or resistor is wrong. "
...and measure the battery voltage from chassis to ignition switch out during cranking........gets battery , ground connex, hot side connex and cables all in one shot.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
