Re: 300hyd
Posted by cmd1042 on February 18, 2010 at 04:52:13 from (71.31.62.74):
In Reply to: 300hyd posted by ACSeppo on February 18, 2010 at 00:07:25:
Yes the front seal on the hydrolic pump leaks and allows the hydrolic oil to run into the crank case. normally there is something else wrong with the pump I would not just replace the seal but it is easy to get off so you may just want to change seal to see if it works
