Re: 3588 overhaul: help!!
Posted by mkirsch on February 18, 2010 at 07:42:28 from (67.240.251.254):
In Reply to: 3588 overhaul: help!! posted by Jason Karels on February 17, 2010 at 18:38:52:
That's the engine serial number, and the cab serial number.
You want the tractor serial number, which is on a shiny tag attached to the frame of the tractor somewhere. They used to be on the bell housing, but they started sticking them on the side of the transmission housing with the black stripe 66 series IIRC.
Even with the tractor serial number you may not get the right parts though. Someone could have stuffed a remanufactured DT466 engine in there, so it may not be the original engine.
Someone should be able to provide you with a rebuild kit based on the engine serial number alone!
