Posted by Owen Aaland on February 18, 2010 at 07:45:26 from (198.70.47.146):
In Reply to: Farmall 966 posted by John Benson on February 17, 2010 at 17:45:20:
To remove the valve you need to remove the rubber cap. There is a small snap ring that holds the disk on the valve stem. The valve is removed from the underside of the cab.
If you are expecting the differential lock to completely lock both rear wheels together it's not going to happen. A good working diff lock on a 66 series at best will cause the front tire side walls to flex a little if you are turning on dry ground but the tractor will still turn. Barring excessive front end weights, an 86 series diff lock will cause the front tires to slide under the same conditions.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
