if you have a bearing supply store near you, they can get you a bearing splitter. or grainger , mc master carr or from a tool truck, ie matco snap on ect. but before i"d do that, drop the oil pan and pull the lower cover off the oil pump and look for wear. not uncommon for the bottom cover to get grooves worn in it from the pump gears. a good flat sheet of glass and some emery cloth, use figure 8 motion and level it back out.
