Posted by Pete7 on February 18, 2010 at 10:04:02 from (72.65.47.188):
In searching the archives on this site I came across a great tip from The Tractor Vet on how to install a clutch "the spring damper goes to the pressure plate side , the vary best way to put it together is hang the pressureplate and disc on the input shaft and slide it together but first lock the fingers down , this can be done buy layen your pressure plate down on the floor and using your heel push down on one lever at a time and install a 1/4 inch nut between the lever and plate . NOW most times this is done from the rebuilder and if it already done make sure that you get them out after ya start to bolt the plate to the flywheel then ya just slide the tractor together and install the bolts from underthe tractor thru the hole in the bottom this way ya only have to align the pilotbearing." I was planning on using his idea to put the clutch back in on my Farmall 340. Anyone else use this method? Thank you Tractor Vet! Pete
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
