Re: technical question generic position control valve
Posted by pete 23 on February 18, 2010 at 10:22:28 from (173.87.0.197):
In Reply to: technical question generic position control valve posted by karl f on February 17, 2010 at 21:11:08:
You need a valve with input and output levers with a follow up linkage arrangement. Take a look at like a 4 or 560 with teledepth where all the external linkage is out in the open so you can see it. It would take some pretty sofisticated hydraulics to go along with that as you would need some way to unload the hydraulic circuit once you reached neutral unless you had a closed center system to start with. Look at all the mechanism that is used on say 06 series tractors to accomplish this position control.
