Re: Dual Fuel Farmall H
Posted by MisterT on February 18, 2010 at 12:27:04 from (209.152.78.140):
In Reply to: Dual Fuel Farmall H posted by D Slater on February 18, 2010 at 11:26:58:
Leon Torkelson said: (quoted from post at 20:26:58 02/18/10) Last fall I was able to get my dad s old H back form the son in law of the guy that dad sold it to 35 years ago. The starting tank is missing now but I located a replacement. I was wondering how the fuel lines were run. I know the starting tank had it s own sediment bowl. Did the starting tank line run into the sediment bowl of the main tank? If so there would have to be a place to screw it into. Or was there a T in the line to run the starting tank line?
Two different methods were used, and I don't know the serial number break, but I think the early version was with the sediment bowl on the starting tank, a petcock (no sediment bowl) under the main tank with a line that ran to the starting tank bowl, and then a line from there around the rear of the engine and to the carburetor. The later version had the petcock under the starting tank with a line running to a sediment bowl under the main tank, and then a line from that bowl to the carburetor. The 2 sediment bowls in question would BOTH have an inlet as well as an outlet, in addition to the inlet that screwed up into the tank.
