Ok everybody has given you good advice here BUT i think that they all missed it , i could be wrong BUT you did say yo were moving snow with the loader and it DOES have live hyd. on the tractor so there for it has a live pump that is ahead of the dist. and they have been knowen to either shear the key on the PUMP gear or the cam gear. So if it did infact SHEAR the key she is out of time and that is why it will not start . So a little more checking is involved here . Pull #1 plug and start to bring it up on comp. stroke and with the aid of a straw or something soft and long find TDC and check the timing mark on the crank pulley , then remove the dist. cap and look where the rotor is setting then look and see where #1 plug wire is and see if it matches up with the rotor . If not then ya need to start to dig deeper and the first place to start is the PUMP and pray that it is the Key on the pump as it is the easiest to fix with little tear down . If it is intact then i would remove the valve cover and see if the valves on #1 are closed if one of them is open then the ft. of the engine will need to come off and to do that will require a lot more tear down . Keep all of us updated on what ya find so we can try and help .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
